Entry and Exit time for a batch
tnquynh
tnquynh
[ FlexSim 23.0.8 ]
Hi all,
I'd like to record entry and exit time for each batch in the system. Entry time of a batch means the time 1st unit in a batch enters the system and Exit time of a batch means last unit of a batch exits the system.
Currently, I only can record entry and exit time of each object. How can I add "Batch" as 1 more constraint to be considered? And how can I take 1st and last unit of a batch for consideration only?
Thank you.
1695096688539.png 1695096617297.png entry and exit times trial.fsm
joerg_vogel_HsH
here is an example:
It shows entry time and end collecting time in a trigger source code of a queue-
staytime_batch_of_queue.fsm
tnquynh
Thank you Joerg.
I have tried your way to trigger to Queue 5 but it shows stay time of each item only, not by batch. Moreover, is there any way to record it in the statistics collector?
1695108633400.pngentry and exit times trial.fsm
joerg_vogel_HsH
@Quynh Tran, I activated perform batching in queue!
