[ FlexSim 24.0.1 ]
Hi @Jordan Johnson ,
Some of our customers and we are sometimes using empty rows in Model Parameter Table to structure the table a little bit. So something like:
This all works like we expect it to work, except for the experimenter. When using the experimenter the following exception is thrown:
FlexScript exception: Setting rank property on node to invalid number at MAIN:/project/library/Experimenter>behaviour/eventfunctions/refreshScenarioTable
This happens when selecting the parameters you want to use in the experiment.
Would it be possible to let the experimenter work with these empty rows or is this just something that should not be done?
Thank you in advance,
Patrick
