Empty rows in parameters table
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 24.0.1 ]
Hi @Jordan Johnson ,
Some of our customers and we are sometimes using empty rows in Model Parameter Table to structure the table a little bit. So something like:
This all works like we expect it to work, except for the experimenter. When using the experimenter the following exception is thrown:
FlexScript exception: Setting rank property on node to invalid number at MAIN:/project/library/Experimenter>behaviour/eventfunctions/refreshScenarioTable
This happens when selecting the parameters you want to use in the experiment.
Would it be possible to let the experimenter work with these empty rows or is this just something that should not be done?
Thank you in advance,
Patrick
JordanLJohnson
Please avoid making blank rows for now. There are many, many places that assume that every row in a Parameter table is a valid parameter with a unique name. This includes the Experimenter, not only in the view as you discovered, but also in the database logic, and probably in the Performance Measures window logic, and likely many other places.
I will add an item to the dev list regarding this issue.
Jordan Johnson
Principal Software Engineer
joerg_vogel_HsH
@Patrick Zweekhorst ,If it couses such problems, then any blank parameter can be replaced by a name for those parameters, which make it even stronger a section line like "xxxxx1xxxxx*.
patrick_zweekhorst
@Jordan Johnson , @Joerg Vogel
Thank you both. I will probably make a script to give all the empty names a unique name, something like xxxxxMachineSettingsxxxxx
jason_lightfootVL7B4
Instead of using separated sections of one table you could also use additional parameter tables with names to match your section descriptions.
