drawFinish error
drawFinish error
sachin_n
drawFinish error
sachin_n
[ FlexSim 19.2.1 ]
I have been getting this error, not sure why. exception: EditorSpatial::drawFinish() . This makes the instance crash (unresponsive). Anyone come across such an issue?
mischa_spelt
Hi Sachin, when do you receive this error? Can you reproduce it consistently? Is there a specific model you can share, or does it happen in an empty model? Which action are you trying to do when you get this error?
sachin_n
I think I have found the issue. Its related to graphics setup. When I updated to 19.2, I did not add the application to the list for customized 3D settings. Set the Vertical Sync to 'Use Driver Settings', set Conservative Morphological Anti-Aliasing to 'Enhance Application Default Setting' and Anisotropic Filtering to 16x. This fixed the issue for now. The issue just randomly started happening to a model I was building, nothing significant, infact I only had 3D objects to track their status, everything else was in process flow. So not a graphics resource hog.
