Dll execute error
Dll execute error
nguyenthanhnam2310
Dll execute error
nguyenthanhnam2310
Recently I tried with the DLL function in FlexSim.
I wrote a simple dll like adding two numbers of type double, but when I ran, it didn't return the total but only the first input number.
I want to know why this happen and how to avoid it when I build the dll.
Below is my code in dll
// C LIBRARY FOR INPUT/OUTPUT STREAMS
#include <stdio.h>
#include <math.h>
// IN ORDER TO HAVE ACCESS TO FLEXSIM FUNCTIONS, INCLUDE FLEXSIMDEFS.H
#include "FlexsimDefs.h"
visible double dllcommand1(FLEXSIMINTERFACE)
// test passing parameters in usercommand
string par1=parstr(1);
pt("string parameter ");pt(par1);pr();
return 0;
visible double mydllfunction2(FLEXSIMINTERFACE)
pt("This will print to the Output Console");pr();
return 0;
visible double addfunction(double p1, double p2)
double a;
a = p1 + p2;
print(a); pr();
return a;
PS: the function mydllfunction2 is working fine, but the "addfunction" have the problem. I also attach my model too
joerg_vogel_HsH
I have never done this before. But “a” is a command itself in FlexSim. So I would try to change the name of the local variable into a string that does not collide with any command featured in FlexSim or any other loaded library of the DLL.
nguyenthanhnam2310
I try with other way in the C++ source code, and it worked.
And I think it's good to name the function is not collide with other functions as you suggest.
Below is what I changed.
visible double addfunction(FLEXSIMINTERFACE)
double p1 = parval(1);
double p2 = parval(2);
double Total_2num;
Total_2num = p1 + p2;
print(Total_2num); pr();
return Total_2num;
Anyway, thank you for your advice.
