Display Simulation Time as Text or bill board in 3D space
karthikeyan_b
Message 1 of 8
karthikeyan_b
[ FlexSim 19.1.0 ]
Hello
I was wondering if there is a way to just get the real runtime clock to display as a text in the 3D model for easy viewing.
I am trying to add the simualtion timer next to some 3D objects to see how it reacts based on time.
I was able to customize the clock as shown in the picture but it counts in minutes and seconds.
I have seen this example shown below in the Q and A forum but was not able to use that in the code.
Can some one show me an example ?
getmodelunit(CURRENT_TIME) //Returns FS_DATETIME
time() //Returns model time
convert(time(), MODEL_TIME, DATETIME_STR) //Will print out date time based upon the date/time format string, for example 8:00:00 AM Fri 24 Jun 2016
Replies (7)
Message 2 of 8
Matthew_Gillespie
What format do you want it to display in? Did you try the Use Default Format option?
Matthew Gillespie
FlexSim Software Developer
Message 3 of 8
karthikeyan_b
Hello Matt , I am trying to display it in seconds.
2400000.00 seconds ~ 66 Hrs
SSSSSS.SS
Message 4 of 8
Matthew_Gillespie
In the Text object's Display Text field put this line of code:
textnode.value = string.fromNum(getmodelunit(CURRENT_SECOND), 2);
Or if you just want it to display in whatever units the model is using you could do
textnode.value = string.fromNum(Model.time, 2);
See this example model.
timedisplay.fsm
Matthew Gillespie
Message 5 of 8
karthikeyan_b
Brilliant , Thank you @Matthew Gillespie
Message 6 of 8
PaulPNEM4H
how to display hh:mm:ss? instead.
Message 7 of 8
moehlmann_fe
That should mostly be the default. Fust choose the "Display Date and Time" option for a billboard text. Then use "Custom Format" and remove the date. "HH" is 24-hour day, "hh" is 12-hour day. In which case you would probably want to use "hh:mm:ss tt" to also display AM/PM.
Message 8 of 8
PaulPNEM4H
There is a scenario where empty totes arrive and wait on the conveyor until the operator loads all items from another source into them. Once all totes are loaded, they move together at the same time. How can you simulate this? Can you create this scenario in 3D?
