display process time
ahmad_zulfy_a
Message 1 of 10
ahmad_zulfy_a
[ FlexSim 23.0.0 ]
shanghai current.fsmHello..
Could you help me to inform how to display the processing time per processor below the processor ?
Replies (9)
Message 2 of 10
FelixMoehlmann
In his comment below the answer to this question, Phil demonstrates how to edit what is shown in the text box of 3d object.
If the process time is a fixed value, you can read it as a property of the processor
("string.fromNum(current.getProperty("ProcessTime"), 2)").
If the value is determined individually for each item, you have to store the value that is determined in the process time field somewhere else (for example a label), so that the OnDraw trigger has access to it.
ShowProcessTime_fm.fsm
Message 3 of 10
joerg_vogel_HsH
Individual_statistics_processor.fsm
individual-statistic-processor.jpgProcess Time and PreDraw Trigger evaluating a number label value.
Message 4 of 10
ahmad_zulfy_a
OK thankyou. can be shown like time elapse from the start until the end of the process ?
Message 5 of 10
ahmad_zulfy_a
But why when start run the simulation it change to show %idle, not always show avgStayTime1678242257570.png
Message 6 of 10
ahmad_zulfy_a
Message 7 of 10
ahmad_zulfy_a
Here is the picture
Message 8 of 10
FelixMoehlmann
The processors that show processing and idle percentage don't have anything set in their Pre Draw trigger.
Message 9 of 10
FelixMoehlmann
You can get the elapsed time since the item entered the processor with this expression:
"current.subnodes.length>0 ? (Model.time - getentrytime(current.first)):0"
It functions like this: Are there any items in the processor? If yes, return the difference between the time of entry and the current model time. If not, return 0.
Message 10 of 10
joerg_vogel_HsH
@Ahmad_zulfy A, current elapsed process time is not as easy to calculate as it seems on the first hand. Yes, you can assume a processing start, when an item has entered a processor. There are other events that can delay this type of information. A setup time occurs before processIng start. A call for operators delays a start until enough operators have arrived. A breakdown could timely happen at the same time, when an item enters a processor. If you then updates the elapsed process time upon entering of an item, the value is possibly wrong. You can only be certain about a stored process time store in a node as a value like a label, Or you can evaluate the process time after finishing processing in processor statistics.
