dispatcher vs process flow
osama_a6
osama_a6
[ FlexSim 21.2.1 ]
Please help! Let's assume you have operators (task executer) go between processers and multiple sinks. I want to do 3 things. First scenario: I want the operators to set on the chair after delivering the package for 5 sec to the processer without using the dispatcher. Second scenario to replace the first: I want to replace it by going to have a tea break by setting down every 2 hrs without dispatcher. I have other questions that might be related or not: I want them to switch between machines regardless of the items there (e.g. first queue, then second queue) with the existence of the dispatcher connection. control_operator2.fsm
SimFlex_support
@Osama A6
You can solve your three issue only using 3D standard dispatcher not using Process Flow.
Second issue is able to solved easily using shift pattern setting. Why do you use process flow?
email ID : support@flexsim.co.kr & support@simflex.co.kr
ryan_c10
Hi @Osama A6,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
osama_a6
Can you please upload your suggestion?
ryan_c10
