Deleting all labels on a 3d object using code in process flow
Kashif_AHMAD376CH
Kashif_AHMAD376CH
I often use this code in process flow to delete all labels on a token:
token.as(treenode).subnodes["labels"].subnodes.clear();
I am trying to use it to delete all labels on a 3d item which is itself a label on the token but it does not work.
token.item.as(treenode).subnodes["labels"].subnodes.clear();
Is there a way to delete all labels on it easily instead of using Remove label option in assign label activity for each labels?
moehlmann_fe
Labels on objects (and any other properties) are part of the objects attribute tree.
You can access the "labels" node under which the labels are stored (and thus delete the label nodes) the following way.
labels(token.item).subnodes.clear();
Kashif_AHMAD376CH
Thank you. This worked!
