Make a time plot chart from global table
steven_chen1
steven_chen1
[ FlexSim 17.2.2 ]
I have a global table with two columns, one is model time for x axis, another one is data for y axis.
Is there a way to build a time plot associate with the global table, and listen to table row added event?
JordanLJohnson
There is no built-in way to make a plot from a global table. You will have to create a Statistics Collector table that copies the table you are making manually.
One way to do it would be to set up a general process flow, with a single token. That token would keep a label for the number of rows it already recorded. It could periodically (every 10 seconds or something) check for more entries in the table.
You could then use a Statistics Collector to log the values found on each row. Here's a model that demonstrates this approach:
Jordan Johnson
Principal Software Engineer
