Debugging DLL
Debugging DLL
mail7WJMZ
Debugging DLL
mail7WJMZ
[ FlexSim 22.1.0 ]
Debugging (flexsim.com)
I tried first method but got error while Visual Studio opening flexsim.exe.
Exception thrown at 0x000000018073B6B0 (flexsim.dll) in flexsim.exe: 0xC0000005: Access violation reading location 0x0000000000000228.
Second method (Attach to Process) works fine.
I use Module SDK to build DLL.
mischa_spelt
Yes, you cannot open FlexSim from Visual Studio. You need to start it as an external application, then attach VS as debugger after it has fully started.
mail7WJMZ
But as I read from user manual, the first method allows Visual Studio to lanuch FlexSim.
Perhaps I have something wrong in Visual Studio settings, or this method is no longer available for latest FlexSim?
JordanLJohnson
The documentation you reference is out of date. I will add an issue to the dev list to update it. @Mischa Spelt is correct, you need to launch FlexSim, and then attach Visual Studio to the main FlexSim process.
Jordan Johnson
Principal Software Engineer
