Database connector to MySQL failed
xueping_l
xueping_l
[ FlexSim 22.1.2 ]
Test Connection fails with the following message: SSL connection error; unknown error number,
It failed to a remote server with the same message. So I tried a local MySQL Server via Docker, which I can connect to using MySQL Workbench without any problem.
xueping_l
8.0 is used for MySQL
kavika_faleumu
Hey @XP Li, have you tried using MySQL 5.7? I also cannot connect using MySQL 8.0 to FlexSim, but I can make a localhost connection fine to the Workbench.
xueping_l
@Kavika F I have yet to try 5.7, but I have a way to make it "work" - simply use ODBC. I tried and it worked - the same MySQL 8.0 server.
kavika_faleumu
Glad you could find a workaround. We will look into this MySQL 8.0 bug to see what the problem may be.
