Dashboard to show contents of combined items?
lambert
lambert
[ FlexSim 23.0.0 ]
I have double stacked pallets and single stacked pallets containing different number of totes (I use combiners to stack them).
When I use a dashboard to monitor the content of a queue, it obviously shows the number of "grouped items" in the queue. In the image below, content = 1.
Is there a way to make the dashboard show the number of totes instead? For the image above, it would be (12+16) = 28
Thank you
m_rosadini
Hi Lambert,
one possible solution would be to create a label in the queue and every time a pallet enters, increase its value by the number of totes inside that particular pallet (pallet.subnodes.length) and decrease it accordingly when a pallet leaves. Then, on your dashboard you can graph the value of the label instead of the content of the queue.
lambert
Thanks Marcello, I forgot to mention that I am interested in displaying time-series charts (i.e. COMPOSITE WIP) grouping several queues (entrance and exit objects).
Would the label method apply as well?
thank you
m_rosadini
Here its an alternative using a tracked variable. You can create one from the toolbox and increase it or decrease it from process flow
support tracked variable.fsm
lambert
this will work like a charm!
thank you Marcello
