Dashboard Error in Evaluation Version 19.0.0
david_l13
david_l13
[ FlexSim 19.0.0 ]
Hi there, I have recently downloaded an evaluation version of FlexSim and am current doing through the tutorial.
When I pinned the Content vs Time stats for the Waiting Line (per tutorial example), I noticed that the x and y axis values cannot be changed. As the default error message is 'No columns Found'.
Would you please help me resolve this issue so that I can continue to evaluate this product? Thank you.
Regards
David
david_l13
See error screen image. Thanks.
patrick_zweekhorst
Hi @David L13,
Have you tried closing the GUI and resetting your model.
It is possible the not all variables are set correctly, which might be solved by pressing reset.
david_l13
Hi @Patrick Zweekhorst, restarting the program fixed the problem. Thank you. Regards, David
