Dashboard button show/hide content
ukasz_e
ukasz_e
[ FlexSim 21.1.5 ]
Is it possible to have a button or a checkbox that after clicking it will hide or show contents of objects in the model?
The case is that i have a button in one of the dashboards, because this model wil open via webserwer. I want to hide or show content to have options to show client simulation model with all 3D objects and not focus on the simulation itself, but on the other hand i want to hide all contents for my symulation to run a little bit faster to generate plots in the dashboard.
Paula_LG
You could write this code inside the button:
int value=switch_hidecontents(object,-1);
switch (value){
case 1: switch_hidecontents(object,0);
break;
case 0: switch_hidecontents(object,1);
break;
This code is for a singular object but it can be adapted to use it, for example, with groups.
You can check this command and many others on this link: https://docs.flexsim.com/en/21.1/Reference/CodingInFlexSim/CommandReference/CommandGroups.html#switc...
I hope it helps!
Jeanette_Fullmer
Hi @Łukasz E, was Paula LG's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
