Custom Packing On pallet
sri_vikas_k
Message 1 of 14
sri_vikas_k
[ FlexSim 23.1.1 ]
Hi community,
In my model, I wanted to pack the items as shown in the following image.
But when I use pack option in the combiner they are seen like this after packing
How to solve the issue?
Thanks in advance.
Replies (13)
Message 2 of 14
joerg_vogel_HsH
Message 3 of 14
joerg_vogel_HsH
This question is related to wherever you stack packed pallets: queues, rack slots and vehicles. @Jason Lightfoot has shown recently a workaround in several of his answers.
Message 4 of 14
jason_lightfoot_adsk
Your desired stacking outcome is now the standard packing method in 23.1 (still no un-packing):
Here's an example model which just uses default behavior.
DefaultPalletStacking.fsm
Message 5 of 14
sri_vikas_k
Hey @Jason Lightfoot
Your suggestion almost helped me, but when I try to pack the 6 items. The first two items are being packed vertically but from the third item they are penetrated into the second item as shown in the screenshot below.
Message 6 of 14
Can you post the model for us to see how it was set up?
Message 7 of 14
sri_vikas_k
@Jason Lightfoot
Please find the example below.
Packing Error.fsm
Message 8 of 14
FelixMoehlmann
Your model isn't using the new packing method. (I assume it was created in a previous version and later saved in 23.1?)
You can copy both the new packing logic and the Pallet flowitem from a fresh model created in 23.1 to your model by copy/pasting the relevant nodes. (The pallet has different shape factors which is why you need to replace the old flowitem)
Then set the pallet to use the Pallet Stacking packing logic and adjust the size back to what you are using in the model.
Message 9 of 14
sri_vikas_k
Hi @Felix Möhlmann
You are right! The model was built in previous version and saved in the latest version.
As you said I have copy pasted the Pallet stacking node. But I have no idea what it means by pasting pallet object.
Could you please look at my model.
Thankyou.
Packing Error.fsm
Message 10 of 14
Change all pallet sources to use pallet2 (3 are invisible) and set pallet2 to use the PalletStacking method.
packing-error_jl.fsm
Message 11 of 14
sri_vikas_k
@Jason Lightfoot
I have done it in this way, Not sure weather it was correct!
Would you please look at the model.
Packing Error_node paste.fsm
Message 12 of 14
No it's not correct - why did you rename the pallet from pallet2? Now you have two subnodes with the same name which can only cause issues.
When you see errors in the system or compiler console, they are not to be ignored.
Message 13 of 14
sri_vikas_k
It was packing in this way
packing-error-node-paste.fsm
Message 14 of 14
We can go back and forth with messed up models all day. Use the one I uploaded above.
(Update: You didn't choose pallet2 for sources 3,4 and 5 for which you will also need to copy across the resize oncreate trigger)
