Createevent: Event in the past Error
Ana_Madureira
Ana_Madureira
[ FlexSim 23.2.3 ]
Hello! This errors appear after running Experimenter and allways for AGV's from the Process Flow "AGV_SAS".1713263550369.png
I can't find the cause, because in the Event List it refers to an event at time 0, but all the events seam correct or at least expected.
I've seem similar questions, but all of those times and negetive and not 0. Besides, all of my distribuitions have a minimum greater than 0.
If any Flexsim Developer needs the model I'll make this question private.
Thank you in advance.
sam_stubbsYXX86
Do you have something like a scheduled source, date/time source, or some other schedule of objects that has a Statistical Distribution for the arrival time? Sometimes you can get into trouble if the distribution you are using randomizes the arrival time to a time before the current runtime of the model.
jason_lightfoot_adsk
Please right click a path and choose Refresh Path Links->Entire Network and let us know if you still get the problem.
Ana_Madureira
It worked! Thank you
Ana_Madureira
No, nothing, at least not for the AGV's that are causing the problem. But @Jason Lightfoot answer solved the problem.
Thank you!
