create diverts on sorter in flexscript
gguedia5QZFN
gguedia5QZFN
[ FlexSim 23.1.0 ]
Hello team,
Using flexscript, I want to create a system of conveyors which looks like the image below. it is a sorter with multiple diverts. as you can see here are the specificities which I have no clue how to do that in flexscript.
- diverts on both sides of the sorter
- some diverts are are 90 degree connected to the sorter and some are not
- the sorter itself is not along the x axis neither the y axis
I know how to create a conveyor using flexscript. now I don't know how to position the divert on the left or right at a specific orientation (90d or 60d)
I really appreciate any help with this.
moehlmann_fe
Transfer are automatically created between intersecting/touching conveyors. All you need to do is position the end points of the conveyors accordingly.
FlexSim provides a vector class (Vec3 class) that can make some operations (like finding a vector in a 90° angle though the corss product) easier.
The rest would be scaling of the vectors and multiplying them with a rotation matrix.
// Example of how to set the end points of a conveyor
Object conv;
conv.setProperty("StartLocation", Vec3(0, 0, 1)); conv.setProperty("EndLocation", Vec3(10, 10, 1));
gguedia5QZFN
thank you Felix, I did not know about this class Vec3. it looks like, I can achieve my goal with this. my question now is what if conv is not an Object but a treenode? because I tried the line of code below but flexsim does not like it.
  1. conv.setProperty("StartLocation", Vec3(0, 0, 1));
moehlmann_fe
As long as "conv" does refer to the conveyor node you can cast it as an object. Either as a separate variable or like below.
conv.as(Object).setProperty(...)
