Create a "State Table" with states by Flexscript
royjuventus29
royjuventus29
Hello, I used the following script to create a "State Table". However, there is nothing inside. I would like to have states in it by default like the default state table. Can anyone tell me how to do it? Thank you very much!
treenode statetable = Tools.create("StateTable");
FelixMoehlmann
You can create a default state table by adding "Default" as the second parameter of the create method. Once created you can edit the table like a global table by casting the data node as table.
Object stateTable = Tools.create("StateTable", "Default");
Table data = getvarnode(stateTable, "data");
data[1][2] = "VeryIdle";     // Set name of first state
royjuventus29
By the way, do you know how to attach this state table to a dashboard "State Bar" by Flexscript?
FelixMoehlmann
royjuventus29
Thank you for the answer. It works now.
