conveyor
conveyor
3250716938
conveyor
3250716938
[ FlexSim 24.2.1 ]
why the DP1 logic has not happen? thanks
conveyor.fsm
joerg_vogel_HsH
There aren't any transfer objects in your system. You have moved two seperate segments of conveyors together building a crossing visually. The engine has not created any transfers automatically at the borders of the segments. Please draw a segment end to a side of existing conveyor and you will see that the side skirts creates a gap and a additional object occurs that looks like a square wireframe. This wireframed object is a transfer.
Hi I update the model why the station has not worked, I draw segment end to a side of existing conveyor this time.
here is the model
conveyor1.fsm
FelixMoehlmann
An item can only be send through a side transfer if it's leading edge has not yet reached the transfer point. In your model you'd need two stations, one for each incoming conveyor ahead of the intersection.
joerg_vogel_HsH
It is still a discrete event simulation. On a conveyor system entering, processing, leaving must occure each step one after another. You can adjust with small gaps this situation yourself. Alternatively you add a fixed resource object in the middle of the crossing.
conveyor1_jv.fsm
ok, I get that! thanks!
