Changing speed resumes stopped conveyor
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 24.2.0 ]
I have a conveyor that is stopped for some reasons in my model. There is some other logic that is changing speeds of conveyor (or the max speed they are allowed to run at during some time windows). When the speed is changed the stopped conveyor also starts running again. Since no resumeobject is called I would not have expected the conveyor to start running again.
Is this a bug, or just the way it works?
I have attached a simple example model. At time 100 the middle conveyor is stopped. At time 125 the speed is changed and the conveyor starts running again. In the tree I can however still see that the conveyor should have been stopped:
This seems to be messing things up when the logic stopping and starting conveyors starts running again.
Thanks in advance.
Patrick
SpeedChangeStoppedConveyor.fsm
logan_gold
I believe this is a bug, so I've added it to the development tracker. I couldn't come up with a good workaround, except to not change the speed of the conveyor until after it is resumed.
logan_gold
Since this has to do with Mass Flow Conveyors, it might be related to the other post about stopping and resuming Mass Flow Conveyors. It may work if the Mass Flow Conveyor is stopped with a Motor, but like I said in the other post, I haven't had a chance to test it out yet.
patrick_zweekhorst
Hi @Logan Gold ,
Attached is the model with the motor in it. I gives the same result as without the motor. We are very curious for some solutions or bug fixes for these problems. I also tried it for the other post.
SpeedChangeStoppedConveyor_Motor.fsm
Patrick
