Conveyor entry /exit transfer generic code?
rajankur6494
rajankur6494
[ FlexSim 23.1.0 ]
Hi Team,
I would like to know if there is any generic code available to get entry/exit transfer of conveyor. It will speed up the process using copy/paste from one conveyor to another conveyor object of same type.
For example: We can get any in object reference using current.inObjects[1].
Thank you!
natalie_white
jason_lightfootVL7B4
I've already sent in a request to be able to find references to conveyors from conveyor transfer objects using a supported api/class/method strucure.
At the moment you need look through the conveyorPoints and determine which points your might be interested in - the conveyorPoints includes references to decisionPoints, photoeyes, stations, inline and side transfers and transfers to fixed resources.
This code finds transfers to fixed resources:
Object conv=Model.find("StraightConveyor1");
Array transfers=[];
Object frTransfer=library().find("?FRTransfer");
Object o;
forobjectlayerunder(getvarnode(conv,"conveyorPoints")){
    o=node("+/~",a);
    if (classobject(classobject(o))==frTransfer)
        transfers.push(o);
return transfers;
julie_weller
Hi @Ankur A3, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
