Convert an Item into two fluids
jean_baptiste_g
jean_baptiste_g
[ FlexSim 18.0.2 ]
Hi all,
I need to simulate a machine that breaks eggs. How can I configurate the ItemToFluid for convert a item (an egg) into two fluids (egg yolks and egg white) ?
Thank you in advance for your answer.
monika_k
Hello Jean-Baptiste,
I have prepared a simple model (model-egg.fsm) that reflects your problem. model-ptrscr.png
You need to have two output connections prom your ItemToFluid object (two separate FluidTanks – one for egg white and another for egg yolks). Then when you open ItemToFluid properties window you need to specify Output Port scale factor (as shown in the picture item-to-fluid.png). It means the distribution between egg white and yolks.
Good luck!
