Controlling unload position upon unload from agv
sakamoto_ryosuke
sakamoto_ryosuke
[ FlexSim 19.0.5 ]
During simulation, upon arrival at warehouse (queue) the agv unload its workpiece (dark green).
See capture1
However, the workpiece is placed on top of the light green material. I would like it to
place it directly on the queue object. (for example See capture3) Is it possible to control the location?
If possible, how can I do that?
Figure1
Figure3
test-warehousearea-20200221.fsm
Thank you in advance.
joerg_vogel_HsH
You want to override engine driven methods. You are allowed to do this, but then you must replace ALL the events and actions that are implemented in the engine code.
  1. Queue Property - Item Placement: Do Nothing
  2. Queue On Entry event set location of item in queue. (Applies only for AGV module, otherwise you must let the taskexecuter travel to location to force an offset travel and then you move the object into the queue)
additionally if you build upon 3D model logic
  • set value of node in queue nroftransportsin or notify queue that “transport in” is complete by command, if you have implemented offset travel and moved the item.
sakamoto_ryosuke
Hello @Jörg Vogel
Thank you for your reply.
I get the point. I think I will try not to go that far at this time.
lars_jacobsen_ScandiSim
You can replace the standard item placement logic of a queue with process flow logic. Use Process Flow / Add a Fixed Resource Process Flow / Queue.
Attach this process flow to your Queue "WarehouseA" as an "Attached Object (instance).
Now the process flow controls the item placement and you can modify the code to suit your requirements.
ClairAu
Hello @Ryosuke S,
You could also use a Rack object as an alternative. In its properties, check Floor Storage:
You can also change Place in Bay / Place in Level to pick where you want to store your products.
In the attached small example floor-storage.fsm, products are stored in the first available bay and level of the floor storage:
sakamoto_ryosuke
Hello @Lars Christian J2,
Thank you for you guide to the Queue logic. Since I'm just a month user of the FlexSim I didn't know where the logic was. It was very helpful.
sakamoto_ryosuke
Hello @Clair A
Thank you for sharing your idea.
I've thought about something similar (though I didn't know how to do it until I saw your sample. Thank you!) , but since various size of material will be stored, so I was thinking it may no be a feasible solution this time.
But, once again, thank you.
