ConfigureWizard
ConfigureWizard
amerloQ2XZU
ConfigureWizard
amerloQ2XZU
can you confirm that the batch file to configure the wizard in VS2015 for FlexSim module DLL contains a little error? I try to use it but VS 2015 doesn't work. I change configuration of the batch file and then everything works. The attached picture shows more details.
JordanLJohnson
Did you have VS 2013 installed previously? Or does your computer have 2015 exclusively? I am wondering if this issue only occurs where 2013 was never installed.
Jordan Johnson
Principal Software Engineer
amerloQ2XZU
I had installed only VS2015 and I confirm that in an other machine where VS2013 is installed everything works.
JordanLJohnson
Thanks for looking in to that, and for testing it, and even finding a solution! I pushed the change to the Module SDK repository.
Jordan Johnson
arunTTT2P
Hi Alessio Merlo,
Can you explain how you changed the configuration from 12 to 14 for the bat file and what's the principle behind it?
Arun KR
amerloQ2XZU
Hi @Arun KR,
here more details about wizards of visual studio
https://msdn.microsoft.com/en-us/library/e06awfzy.aspx
Simply the number indicates which version of visual studio you want to use. 11 is VS2012, 12 is VS2013, 14 is VS2015 and go on. To modify the batch you can simply edit it like a .txt.
