configuration Task executer
garyquelca910
Message 1 of 15
garyquelca910
[ FlexSim 18.2.2 ]
Good evening I would like your help for the following problem:
In a process you need an operator and a transpallet to take a product to store, in this case the product would be a flowitem, the operator a task executer, I have doubts about how the transapallet would represent, that is, the operator goes through the transpallet and pick up the product, I would greatly appreciate your help with an example. Thank you.
Replies (14)
Message 2 of 15
jeff_nordgren
@Gary Q
Could you send in your model or a sample model of the problem? You mention that the transporter goes through the transpallet but without a model to look at it would be very difficult to give you an accurate answer to your question.
Thanks.
Message 3 of 15
garyquelca910
@Jeff Nordgren
Here is the model:
the taskexecuter 1 should be the transpallet, it could be said that the flowitem needs the operator and the trasnspallets (task executer1) to send the product due to the weight of the product I hope your help thanks.operator.fsm
Message 4 of 15
joshua_s
Is this visually what you are looking for? 15441-operator.fsm
Message 5 of 15
garyquelca910
@Joshua S
yes thanks, if I have any questions I will let you know
Thanks for the help
Message 6 of 15
garyquelca910
@Joshua S
I have problems in performing the task, this time for a set of operators, using a dispatcher
Message 7 of 15
joshua_s
@Gary Q
Can you send your model, the model I sent was custom tailored to your previous process, and won't work for a dispatcher. You would need build a dispatching type of system in process flow.
Message 8 of 15
garyquelca910
@Joshua S
Here is the model, in this case are more operators, the operation should be like the previous model that sent me
I would like your help operator.fsm
Message 9 of 15
joshua_s
@Gary Q
How would you like your process to work? Should there be as many transpallets as operators?
Message 10 of 15
garyquelca910
@Joshua S
Exactly there should be as many transpallets as operators
a question in case of using the experienter, specifically in increase or reduction of operators and transpallets
There will not be any problem?
Message 11 of 15
joshua_s
@Gary Q
Here's the model where you can vary the number of operators and Transpallets based of labels on Queue1. I Also added an experimenter with scenerios based on the label changes on the Queue1, so you can see what happens with an increase in Operators and Transpallets.15485-15441-operator-1.fsm
Message 12 of 15
garyquelca910
@Joshua S
Message 13 of 15
joshua_s
@Gary Q
Take a look at my previous comment which has a model in it.
Message 14 of 15
garyquelca910
@Joshua S
Thanks for the help
Message 15 of 15
garyquelca910
@Joshua S
sorry, how can I make it so that the conditions of the model are met, where there are separators and queues where the requirements are by type of item groups.fsm
