conditional decide based on time range
amy_milesB7Q7X
amy_milesB7Q7X
[ FlexSim 21.2.3 ]
I want to check to see if I'm on 1st shift or not. I have a decide and I can do Model.time<x hours but that only works for a day. What would be the syntax to say is time between 8am and 4pm so it works if I run the model a week? Or is there a way to designate shifts?
Ben_WilsonADSK
FlexScript's DateTime object has an hour property that can be queried to give you the model's current hour of the day. See the documentation:
FlexScript Class - DateTime (flexsim.com)
So you can get the model's current hour, then use that in your logic:
double currentHour = Model.dateTime.hour;
You might check out Time Tables as a way to define shifts, along with behaviors that happen at the start and end of the shifts.
amy_milesB7Q7X
Thanks Ben,got it to work, could not find how to say "between" but just discovered the code builder and was able to do > and < using &&.
