Concurrent Processes
maryamh11
maryamh11
[ FlexSim 21.1.4 ]
How I can create two concurrent processes in the same activity set each of which has different processing times. To explain more, I have an exam room process in which the processing time follows a triangular distribution. It contains three activities A, B, and C, and each of these activities have specific and fixed processing times. I want to make just activity B ( with X minutes of processing times) concurrent with the whole exam room process. How it could be possible?
Thanks!
joerg_vogel_HsH
Your constant process time (B) must be fitting into the triangular distributed time. It is a maximum of two values
Math.max(const. time B, triangular distribution)
https://docs.flexsim.com/en/21.2/Reference/CodingInFlexSim/FlexScriptAPIReference/Data/Math.html#Met...
maryamh11
@Joerg Vogel My question is how I can create two concurrent processes in the same activity set.
eric_m3
Would using Split and Join activities do what you're wanting? That way you could send the split tokens through different delays at the same time.
maryamh11
Seems a good idea! I'll try that. Thanks!
