Combine and seperate on conveyor station
tushar_hazare
tushar_hazare
Hello All,
I am trying, at station1 2pallets will combine and this 2pallets move further and at the station4 these 2 pallets will separate and move.
At the station1 pallet will stop and wait for second pallet to combine.
please find the attached model.
Thank you in advance
tushar_hazare
Hello All,
Waiting for response....
Thank you
joerg_vogel_HsH
A station is a subsystem of a conveyor. Items inserted on a conveyor are conveyoritems. If you want them to be assembled then one item leaves the system and becomes a subnode of the container item. Such an operation needs an exit transfer to let leave the item on a conveyor. This part of your question can you also realize just by Flexscript or process flow without the need of an exit transfer. The function that assembles items is called moveobject as a Flexscript command or Process Flow activity.
On a station that dissembles items you need to insert an item in an entry transfer, because it must become a conveyoritem again. This operation is not intended to be done by source code. You must have an entry transfer, which will manage the gap to pass an item into a conveyor system. Easiest would be you move the stacked item to a queue object by Flexscript or process flow. Then this queue will sends its content to this conveyor near your station into a site entry transfer.
You can get a new reference to your assembled item by properties first, last, rank or subnodes.
Hint: If you don’t want to see the queue, then you can hide it visually.
Pooja_inde
tushar_hazare
Hello @joerg_vogel_HsH Can you please help me to apply this above logic in my model.
Thank you in advance.
moehlmann_fe
Is it important that the pallets do actually "combine"? What you could do is use two Decision Points (they have less build-in functionality than a station and are thus easier to use for custom logic) and wait until an item has arrived at each of them. Then continue both. By setting the processing time of the station to 0 for every second item, the pair will move along the conveyor together, since the second pallet never needs to wait.
joerg_vogel_HsH
I won’t do it.
