Checking object status, flex script
sandeep_kumar_i
sandeep_kumar_i
[ FlexSim 19.2.4 ]
Hello FlexSIM users
I am looking for the command to check object status as breakdown or not in Decide command to proceed to next operation in process flow.
For example, to check if my machine is down, before moving item to my machine.
Best,
Sandeep
sandeep_kumar_i
Jacob_Gillespie
The state of the machine could be checked using this:
Model.find("Processor1").as(Object).stats.state().value
That gives you a number or you can get the string version of the state:
Model.find("Processor1").as(Object).stats.state().valueString
philboboADSK
You can stop an object in any state.
If you want to see whether an object is stopped, you should check its "nrofstops" variable:
Object obj = Model.find("Processor1");
int isStopped = (getvarnum(obj, "nrofstops") > 0);
return isStopped;
Phil BoBo
Sr. Manager, Software Development
