Change view perspective with code
julio_r
julio_r
[ FlexSim 18.0.2 ]
I´m trying to make a simple code that replicate de effect on clicking on the save views name in the Quick properties when we click on the model floor.
Is there a command or a different way to accomplish this?
Matthew_Gillespie
string viewName = "View 1";
applicationcommand("changeperspview", viewName, activedocumentnode());
Matthew Gillespie
FlexSim Software Developer
julio_r
Thank you so much, that's exactly what I needed.
nmzenke
This works well running in the script window if the 3D view is already the selected window. Is there a way to make this work when some non-3D window is active? For example, I want someone to be able to push a button (run the code in the onPress) on a dashboard and have the model open up a 3D window in the specified view.
@Matthew Gillespie
Matthew_Gillespie
This answer shows you how to loop through all open 3D views.
To open a new 3D view you can use this command:
treeenode newView = applicationcommand("perspectiveview");
Either way you just replace activedocumentnode() with your chosen view.
Matthew Gillespie
nmzenke
That worked great. Thanks!
