Change processor animation sense
RogelioG
RogelioG
[ FlexSim 23.1.0 ]
processor.jpgHello everybody,
exist any way to change the sense of the animation of the processor, I mean, if is possible to show the process animation from right to left instead of the standar sense.
I want to show animation in order to reach work table operator
jesus_evangelista
Hello, Roger!
I found a way to get what you need done, as I understand.
If you click on the Processor and then click on "More Visuals" you can get to the menu. There you can access to the "Shape factors" and change the rotation values. You can set the rotation in Z at 180, and then manually rotate your Processor to get it jus the way you need it. You can replicate it using the connections of your model.
I attach a short video of what I explained and the model of it, too.
Hope it is usefull!
ChangeAnimationSense.fsm
logan_gold
Hi @Roger, was Jesús Evangelista's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
RogelioG
Awesome!
that is exactly that I was looking for, thanks.
RogelioG
Bien!
excelente aporte para mantener la imagen y el flujo de material en el sentido correcto y acorde al escenario, gracias!
