[ FlexSim 20.1.1 ]
I have been trying to implement "Case when then else end" statement in flexsim but I think I am getting the syntax wrong. Could you please guide?
int entry = Table.query("Select label_name from ListName CASE WHEN label_name =$1THEN label_name END", token.label_name)[1][1];
In the above query, I want to check the list (ListName) for the presence of a particular part which matches with the information being carried by the token's label (label_name).
It may so happen that the list may not have a part which matches with the label of the token. In such a case it needs to return a NULL value. Assuming like in SQL, when else is not mentioned in the query it return a NULL value I have left it from this query as well.
