¿Por qué se bloquean operarios?
beatriz_dt
beatriz_dt
En el modelo adjunto, quiero poner que en los procesadores "Doblado" y "Soldadura" utilice operador para el Setup Time, pero al ponerlo se me bloquean ambos procesadores. Para tener la configuración de operadores, tiempos y transportes igual que aparece en el modelo adjunto, ¿Qué tengo que modificar/añadir en el modelo para que no se bloquee?
PruebaBloqueoProcesadorAmpliada.fsm
parker_s
@Beatriz DT
This is happening because the operator gets stuck trying to unload the items but can't until the setup on the first item is started, but the setup can't happened until the operator has unloaded all the items.
This can be done in process flow, please review the process flow and task logic tutorials found in the guide:
https://docs.flexsim.com/en/21.1/Introduction/QuickStart/QuickStart.html
Ben_WilsonADSK
Hi @Beatriz DT, was Parker S's answer helpful? If so, please click the red "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
