Can I make task executor load entire queue as trailer?
jkhedekar
jkhedekar
[ FlexSim 21.0.10 ]
So I am loading objects onto queue with forklift which imitates loading onto trailer. After loading 5 items I would to pull tat queue by a task executor as a truck would pull a trailer. How can I go about that?
joerg_vogel_HsH
As it say, a queue is a fixed resource object. It is by default motionless. You can move a queue onto a vehicle or a container item, which becomes a trailer.
OR you set a queue invisible and you put only your items onto a vehicle or container item.
Or you replace your queue right away by a vehicle or container.
jason_lightfoot_adsk
Load them using an AGV.
Option1. Set the AGV type to attach loads as a trailer.
Option2. In code use the AGV's method for attaching trailers.
Option3. Use the custom code activity in a process flow:
Consider using pallet for the loaded items and attaching the pallet as a trailer
jkhedekar
Could you share a model which has loading onto a pallet? Since pallet is a flow item too.
