Can FlexSim take advantage of multiple GPUs available in a workstation?
pcneo
pcneo
1) Is FlexSim designed to utilize multiple GPUs for simulation or rendering?
2) If so, what are the recommended configurations or settings to enable multi-GPU usage?
3) Are there any known limitations or considerations when running FlexSim with a dual GPU setup?
joerg_vogel_HsH
Visual: this depends on the functionality of a graphic card driver to support OpenGL.
Computing: Not in FlexSim‘s basic engine. There is an option for distributed computing. But this is for a setup of multiple computers and not multiple graphic cards. If you bind other programming languages like python to your model, then those can use additional graphic cards resources.
