- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 22.0.1 ]
One of our clients had a problem with task executers not being able to travel along an agv path with forced forward orientation.
We traced the issue to be caused by the calculation of angles between two paths seemingly being influenced by the orientation of the container object. In the gif below, the left path is located inside the plane which is rotated 180° around the z-axis. The path on the right is located under the default AGVNetwork node.
Despite the paths leading smoothly into each other this causes a "phase shift" and the task executer changes its orientation due to the "Turn Around Threshold" being set to 91°.
Not sure if this might be related to the issue pointed out in the post below and thus already on the dev list.
https://answers.flexsim.com/questions/87005/agv-path-in-a-rotated-plane-dont-work.html
