Bug in Operator's Animation
carolina_sdm
carolina_sdm
[ FlexSim 21.0.1 ]
How can I fix a problem that happens in the animation of the operator after she leaves the pallet truck and goes to sit on the chair? She stays with the arms in the walkloaded animation's position, when she should walk normally (with the walk animation).
Ps.: The bug happens after the stop time: 29400.00
Thanks in advance 🙂
Warehouse - Bug.fsm
ryan_c10
Hi @Carolina Sdm,
I was able to fix the issue you were experiencing. It's not actually a bug, but it results from the Operator still thinking she was in a "walking while loaded" state. As a result, she stayed in the "WalkLoaded" animation. Instead of using the "Move Object" activities in the area of the Process Flow used for that Operator, I changed it to use Task Sequences of Travel/Load and Travel/Unload to move the pallet truck into the operator's hands, and the animation now changes properly back to the regular "Walk" animation after she finishes moving the pallet truck.
warehouse-bug-rc-v2.fsm
I hope this helps! Let us know if you have any further questions!
carolina_sdm
Thanks so much, it helped! @Ryan Clark
ryan_c10
Hi @Carolina Sdm,
You're very welcome! Glad to help!
In the future, please add replies to answers by using the "Reply" feature to add a comment rather than adding another answer. This helps to keep things organized on this forum. See Best practices for using this Answers site - FlexSim Community for more info. Thanks!
carolina_sdm
Actually @Ryan Clark , it happens an error in my simulation. The error comes when I put your inputs in my complete model. And the complete model is too big to send here. But have a look, please.
jason_lightfootVL7B4
It's saying that instead of a box the operator is carrying something called paletiera_flow1 which does not have the label called posicao_caixa on it. On the previous model there is no reference to paletiera_flow1 so that must be new in your model.
