Bind NodeListArray from within SDT class
thomas_smithWKC4J
thomas_smithWKC4J
[ FlexSim 23.0.1 ]
I can't figure out how to bind a NodeListArray for an SDT derivative.
For ODT, this is how I would do it for a list of SDTs:
class MyODTType: public ObjectDataType
   NodeListArray<MySDTType>::SdtSubNodeBindingType mylistofSDTs;
   void MyODTType::bindVariables()
      ObjectDataType::bindVariables();
      bindVariable(variable); // <---
My SDTs also need to have a list of treenodes within them. Which bind macro do I use in this example?
class MySDTType: public SimpleDataType
   NodeListArray<treenode>::NodePtrType mylistofnodes;
   void MySDTType::bind()
      SimpleDataType::bind();
      // What goes here?
      // I have tried with no success:
      // bindNodeListArrayAsClass(treenode, mylistofnodes);
JordanLJohnson
To bind a NodeListArray variable in a SimpleDataType, use bindSubNode:
bindSubNode(someNodeListArray, 0)
Basically, since the NodeListArray needs a parent node to place all its list elements under, it can be treated as a node in bindSubNode().
The bindClass() methods/macros deal with adding a new FlexScript API class, rather than binding member variables of a class. For more information, see:
https://docs.flexsim.com/en/23.0/Reference/DeveloperAdvancedUser/ModuleSDK/ExtendingFlexScript/Exten...
There is an example module file available on that page you might find helpful.
Jordan Johnson
Principal Software Engineer
thomas_smithWKC4J
Hi Jordan. This works for binding the NodeListArray, but when I try to add elements to it I am getting an exception.
bindSubNode(mylistofnodes, 0);
mylistofnodes.add(mytreenode); // <--- here
Could be an issue happening elsewhere in my code, but I believe I have isolated it here. I'll investigate, but do you have any ideas on what could be causing this? There error I'm getting is just a generic exception in processeventinlist.
thomas_smithWKC4J
Nevermind, I figured it out. I was creating an instance of my SDT, then adding to its NodeListArray, then adding to the tree.
I fixed it by creating the instance, immediately adding it to the tree, and then manipulating the NodeListArray.
Thanks again for your help.
