Bed TAT Process
Bed TAT Process
maryamh11
Bed TAT Process
maryamh11
[ FlexSim 23.1.2 ]
Hi there,
Is there any way to prevent the automatic allocation of a bed for a turnaround time after a patient is discharged? It would be ideal if there could be a delay period during which the bed remains unoccupied and unavailable for acquisition by anyone else from the resource locations.
moehlmann_fe
Without knowing how the beds are implemented in your model I can only give some general advice.
You can set the Remove Patient activity to only remove the person statistically. This preserves the token which can then enter a further delay until the location/bed is released.
release_after_exit_fm.fsm
maryamh11
@Felix Möhlmann
I believe one issue with this approach is that the patient completely disappears from the model when you statistically remove them. Is there a way to represent a patient leaving the bed, but still being present in the model, so that the bed cannot be acquired within the desired turnaround time (TAT)?
moehlmann_fe
I don't see the issue. In the attached model the patients do leave the bed and walk to an exit before they are removed.
If the patient goes through other processes you can create a parallel branch in the Process Flow that releases the bed after a certain period of time.
release-after-exit-fm_1.fsm
If you are handling the assignment differently than acquiring the beds as a location, you'd have to show your method so we can see in what way the turnaround period could be implemented in your model.
maryamh11
Got it, yeah I think I might split the flow like what you did.
