BackOrder Problem
BackOrder Problem
rocio_alvarez9R3F7
Message 1 of 1
BackOrder Problem
rocio_alvarez9R3F7
Hello, I'm working on a model where I have a group of workstations (Puestos) that I've entered into the list "PuestosSubconj". Each token represents a logistics operator who requests workstations .
When the operator has a material collection order, he looks for a station and leaves the material in the stock associated with the workstations (he has selected from the list "PuestosSubconj") by central port. The token will display the labels for the selected workstation ("Puesto") and stock ("Stock").
If all workstations are filled, a back order is generated in that list when an operator requests a specific workstations.
If there's only one entry in that back order, when the requested workstations becomes available, that entry disappears of the BackOrder and the model works correctly.
However, the problem appear when, after one back order has been placed, another one is placed:
In this case, the first entry in the back orders (id114 instance) was generated by "PuestoSub6".
 In this case, the second entry in the back orders was generated by "PuestoSub1" (id116: instance)
When one of those two positions, specifically, the "PuestoSub6" becomes available, the entry for that position doesn't disappear from the back order (id114: instance), and the PuestoSub6 is also added to the list of "PuestosSubconj".
List Settings:
Logic:
Pull back order and push configuration:
I've created a simplified model of how the BackOrder function of the model I'm working on should work, and this simplified model does work as expected. I've attached this simplified model (BackOrder.fsm).
Could you help with the problem? I'm attaching images to accompany this explanation.
Thanks in advance!
Version 24.1.1
Replies (0)
