Average Output per hour
hh_2105
hh_2105
[ FlexSim 23.2.1 ]
Hi, I am trying to find a way to find out the Average Output/Input per hour to take note of how many tokens go through a certain process in a certain time frame for example 1 hour. The closest way i could get was to enter the tokens through a list or pull them from a list. Other method is to enter them through a zone and pin its statistics. All this method is not useful as i was only able to find the total input or outout, or input/output vs time. I tried finding a solution for this and i see a lot of comments saying there is a throughput template but i cant seem to find it or use it as the template do note support lists or zone statistics.1728962143161.png
Would really appreciate the help. Do send me a simple example of how it should be or feel free to use my fsm file.
avg_output_per_hour.fsm
FelixMoehlmann
You can find output per hour and output by hour chart templates in the dashboard library
hh_2105
Hi Felix, this works with a queue. but for tokens, exitting or entering a list how can i find out the output per hour?
FelixMoehlmann
Link the chart to the Push to List activity (if the tokens stay there until pulled its throughput is equal to the throughput of the list). If there are multiple activities use the "Composite" version of the chart.
hh_2105
Hi Felix, this works, what if I require the output per hour by type.
what should be the type label format for push to list activity?
FelixMoehlmann
Just the label name.
logan_gold
Hi @fiz, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
