Auxilary tasks
Auxilary tasks
luis_rodrigues
Message 1 of 28
Auxilary tasks
luis_rodrigues
[ FlexSim 24.1.0 ]
Hi, I'm working on a model in which the transports have a main task to do, which is loading the queues to que "ML", but they have also some auxilary tasks that take a certain percentage of the total time (24h).
(For example)
The MC1 takes 10,28% of time and later I have made this logic:
I just want someone to confirm is this is correct (I don't remember why I putted 300 😞
mlall-4.fsm
Replies (27)
Message 21 of 28
FelixMoehlmann
No, as I said before, the default states and any additional custom state profiles exist in parallel and the custom states will never change by themselves (apart from the multiprocessor).
Message 22 of 28
luis_rodrigues
Sorry for the misuderstanding, now the only problem is that I selected the multiprocessor in the chart but it gets empty when I run the simulation.
mlall-4-1 (1).fsm
Message 23 of 28
FelixMoehlmann
Sorry for the inaccurate screenshot from before. When settings the state you must reference the transporter.
Message 24 of 28
luis_rodrigues
Thank you @Felix Möhlmann I've done that but the graph doesn't show the names I set.
Message 25 of 28
FelixMoehlmann
State charts show the display names from the State Table they are linked to.
Message 26 of 28
luis_rodrigues
I understood that but you told me to create this in each transporter:
And the chart is getting this list:
Can you help me make this work?
mlall-4-1 (1).fsm
Message 27 of 28
FelixMoehlmann
Create a new State Table and use the sampling tool to fill it based on the "MultiProcessor States" profile of a transporter. Then adjust the "Analysis" column where needed (Utilized is counted for the utilization percentage, Excluded does not appear in the chart at all).
Then link the chart to this new State Table.
Message 28 of 28
luis_rodrigues
Thank you very much
