Attach Items to AGV at front end
arunTTT2P
arunTTT2P
[ FlexSim 18.0.3 ]
Need a modeling idea here. How to attach the loaded item to the front end of the AGV and the loaded item have to behave like an attached trailer following the curves of the AGV network. In other words, like a push train. Set location didn't work for me here, maybe it is because the attach as trailer option is overrunning it.agv-help.fsm
Thanks and Regards, @phil.bobo, @Sam Stubbs, @anthony.johnson
Arun KR
joerg_vogel_HsH
An stupid approach is to set the agv in the front invisible and verry small and change the shape of the last trailer to look like the agv. The Train behaves in the model like a standard train, only the visual looks different.
arunTTT2P
It's working when I changed the trailer attach rule node value to greater than 1. A value of 0 places the item on top of the AGV.
Regards, agv-help.fsm
Arun KR
arunTTT2P
Would have been easy, if the attach rule node value can be changed from the network properties GUI window.
Vinay_S_Jindal
For reference for current users.
Now we can use this code to attach trailer ahead.
agv.attachTrailer(trailerObj, 0.1, 0, 0);
If 3rd parameter is 0, the trailer will attach to ahead, if 1 attaches to behind.
Refer this link from documents for more details.
(flexsim.com)https://docs.flexsim.com/en/23.0/Reference/CodingInFlexSim/FlexScriptAPIReference/AGV/AGV.html#Metho...
