Astart add members by code
omar_aguilera_rico
omar_aguilera_rico
[ FlexSim 19.1.0 ]
Hi. I have a model where I create and destroy objects, the objects that I create add them to a group. I want the objects that are in the group to be added to the astar, how do I do this by means of code? Try adding rows to the tree but I do not know how to modify the value of the member row:
Table thelist = getvarnode(Model.find("AStarNavigator"), "fixedResourceBarriers");
addtablerow(thelist);
joerg_vogel_HsH
You find the commands in the properties view of AStar, if you explore the structure of the window. @phil.bobo has described the procedure for another question and different properties here. If you can select a group to add members to be in the AStar module then you can do it by code, too.
roi_sn
Hi @Omar Aguilera Rico, you can use the next code:
Object agv = Model.find("AGV1");
contextdragconnection(agv,model().find("AStarNavigator"),"A");
omar_aguilera_rico
Hello @Roi Sánchez! Nice to say hello again, thanks for the prompt reply. Regards!
