How to import 3D graphics in flexsim (for flowitem, machines, containers,...)
pierre_b
pierre_b
[ FlexSim 19.1.0 ]
Does someone has success in 3D graphics importing in flexsim (for flowitem, machines, containers,...)Which software has been used, on what file format, what is the import procedure to set scale and orientation ?
joerg_vogel_HsH
This is a top feature in FlexSim. And it has its own section in the manual.
Creating custom objects and animations
> Creating and Importing Custom 3D Objects
If you need animated object you can use the fbx file format of other software packages, the internal animation creator can interact with the material flow and the kinematics can control the material flow, because it returns times how long the animation lasts.
pierre_b
Thanks. Do you recommand a software to create 3D shapes exportable in fbx format.
SCHamoen
@Pierre B If you just want to import different shapes without needing animations directly take a look at the 3D warehouse for sketchup. Flexsim imports *.skp files until version 2015 very nicely
Other good and simple software is AC3D or the very powerfull and free software (but somewhat complex) Blender.
If you want to know more about fbx, please search this forum and you will find lots more information
joerg_vogel_HsH
The manual recommends some software packages in the section Creating Custom Animations
