Assign virtual distance by code
omar_aguilera_rico
omar_aguilera_rico
[ FlexSim HC 5.3.4 ]
Hello everyone. Is it possible to assign the virtual distance between a path NN1 to NN2 per code? Try doing it with setvarnum () but do not succeed. Any idea how I can do this? What I want to do is that the virtual distance depends on a global table. I appreciate the support. captura.png
philboboADSK
treenode NN = model().find("NN2");
int connectionNum = 2;
double newValue = Table("GlobalTable1")[1][1];
setsdtvalue(connectionsout(NN).subnodes[connectionNum], "userDistance", newValue);
optimizenetwork();
Phil BoBo
Sr. Manager, Software Development
omar_aguilera_rico
Hello, I already tried with the code that you indicated me but the subnodes do not detect it and it marks me error. Attach the support model so that you notice that it does not detect that command. Thanks for the support! It is the version of FlexSim HC 5.3.4 problema.fsm
Matthew_Gillespie
Dot syntax is not supported in HC. Change
to
rank(connectionsout(NN), connectionNum)
Matthew Gillespie
FlexSim Software Developer
omar_aguilera_rico
How to represent in HC string.fromNum()?
Matthew_Gillespie
numtostring()
Matthew Gillespie
