Assign 2 operators to carry one object
swaraj_k
swaraj_k
[ FlexSim 20.0.10 ]
While learning new things, I came up with a situation where a heavy part of approximately 30 kgs. is being lifted by two operators to load on a milling machine. I want to replicate the exact scenario in flexsim and test the throughput of the process and the worker's efficiency.
FelixMoehlmann
There is a tutorial that deals with this exact situation and shows how to use a process flow to achieve this.
https://docs.flexsim.com/en/20.0/Tutorials/TaskLogic/Tutorial2CoordinatedTasks/CoordinatedTasksOverv...
Rather than create the items in the process flow, you can also react to them arriving in a queue with an Event-Triggered Source.
Aside from process flow, you can also create the needed task sequences in code. This is demonstrated in the "Coordinated Task Sequence Example 2" Use Transport option.
twoOperators.fsm
swaraj_k
Thank you so much!
