- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 21.1.0 ]
I have been having some problems with the display of my ASRS vehicle in 21.0.2. While investigating I have also upgraded to 21.1.0. Immediately after upgrading I had an error on autosave: (this was while I was multitasking and looking at the results of a different model, also in 21.1.0)
The file size of the autosave was 3-4 times the size of the original file, but I managed to re-save and the size went back to normal, model runs, everything seems OK except for a persistent error message: (maybe related to the fact I just removed a background file??)
So I was then following through the instructions from this answer:
https://answers.flexsim.com/questions/76875/why-asrs-vehicle-form-isnt-convenient-when-changin.html#
I was in the Visual editor trying to change the height of the car, so that the ladder will be shorter.
While in the throes of fiddling with this another autosave happened, this one spawning an even more drastic message:
soo... here it is....
WIP_ASRS_Vehicle_Display_Problem_1_autosave_recovery.fsm
And this is before the autosave:
WIP_ASRS_Vehicle_Display_Problem_1.fsm
If you need the 20.0.2 version I may have to get rid of some confidential info but then I will be able to send it to you.
Thanks!
