Array index out of bounds: Assign Labels
e_yiing98
Message 1 of 8
e_yiing98
[ FlexSim 21.2.4 ]
example model.fsm
4 totes arrive at buffer2 every 10 seconds, each tote will be sent to the input queue of the processor.
I assign a label called destination, value is the input queue of processor.
But it comes out exception error, what's wrong with the activity assign label?
Any advices is much appreciated.
Replies (7)
Message 2 of 8
FelixMoehlmann
The processors WireBond12, 13 and 14 are not connected to their queue. So "inObjects" is empty and trying to read the first inObjects causes the error.
Message 3 of 8
e_yiing98
After connecting processors and queues, the model still not working well.
In Processor process flow, I found that token enters <Push to List> has assigned label <destination>, however when I check the entries, the <has destination> label is still equals to zero. Therefore, agv can't pull anything from the list.
Any mistakes in my push to list/pull to list event?
Message 4 of 8
FelixMoehlmann
The "destination" label is written to the token, but the item is pushed to the list. Since the item still doesn't have the label, the "hasDestination" field returns 0.
Message 5 of 8
e_yiing98
I got it! I should assign label on token.item! Thanks Felix!
Message 6 of 8
e_yiing98
@Felix Möhlmann I have another small question, I have set agv capacity to 4 and pull from list request number to 4, but agv just load 1 item. Could you please help?example model_221207.fsm
Message 7 of 8
FelixMoehlmann
Because you left the "Require Quantity" at 1 the token continues after the first item is created. You think of the two fields as "At most" (Request Quantity) and "At least" (Require Quantity).
Furthermore, if you pull more than one object, the resulting label will contain an array of the pulled values. You will have to load them individually. For example by using a subflow that gets executed for each entry in the array.
I've made those adjustments to your model, but you will have to decide how to handle/adjust the transport of finished items. (Load them if available after unloading an item, then later move them to Buffer3 once all other items are unloaded, for example)
example-model-221207_1.fsm
Message 8 of 8
e_yiing98
Thanks Felix!
